you can add them to the order, i can do 5 bucks better on the prices and shipping on two add another 20 bucks.
aluminium radiator
http://www.lightspeedinnovations.com/product.aspx Looks promising!Traction is optional, so are zipties
92 Gtst/Silver bullet
like with any rad setup its all universal, The fans will come with those straps that go through the rad, use them to your own discression, not hard to custom mount them. Turning them on and off, easiest way is buy a headlight relay and wire them up to iginition, or if you gotta couple extra bux a flex a lite or equivalent thermostat controlled relay you can buy at any auto parts store. No electric setup is bolt in that won't cost you a tonne of money.Originally posted by m_melen View Postbrian, how are the electric fans controlled? do they come with everything needed to bolt them up to the godspeed rad?
Yes the stock fan shrouds fit the ForgedRacing. The tubes on Forgedracing are also 1mm thick instead of Koyo's .8mm and the fin spacing on ForgedRacing is 0.8cm instead of Koyo's 1cm meaning there is way more cooling surface.
No comparison to Mishimoto either as they are not epoxy filled. Also have a lifetime warranty not if you crash your car but then you have bigger problems than a radiator. They are regular $335 we are introing them for $300.00 come with a cap and drain plug not like brand K.Attached FilesLast edited by LIGHTSPD; 03-14-2011, 02:20 PM.Cam Koole
Technical Services Consultant
Lightspeed Innovations
Red Deer, Alberta
1-866-95-84732
cam@lightspeedinnovations.com
www.Lightspeedinnovations.com
North American EMtron Distribution
Whiteline Canadian Distribution Center
EMtron Training Center Coming Soon
2WD Mustang MD250
Dynapack 4000 AWD
Distributer for
Exedy, JE,Carrillo, CP Pistons,
K1 Technology, This is a very
long list and if you actually read it'
cool. Just call we can get it LOL
2WD Mustang MD250
sorry, are you comparing KOYO with ZAP or KOYO with OEM?Originally posted by LIGHTSPD View PostYes the stock fan shrouds fit. The tubes are also 1mm thick instead of Koyo's .8mm and the fin spacing is 0.8cm instead of Koyo's 1cm meaning there is way more cooling surface. No comparison to Mishimoto either as they are not epoxy filled. Also have a lifetime warranty not if you crash your car but then you have bigger problems than a radiator. They are regular $335 we are introing them for $300.00 come with a cap and drain plug not like brand K.
Comparing ForgedRacing to Koyo and Mishimoto
Cam Koole
Red Deer, Alberta
1-866-95-84732
2WD Mustang MD250
Dynapack 4000 AWD
Distributer for
2WD Mustang MD250
