Injector seals and O Rings?
  • Injector seals and O Rings?
    hi, probably a stupid question but was just wondering where about's i can find R32 RB20det injector seals and O rings? anyone know good places to pick these up or order from??
    Nissan. You just need a part # to take with u to make your visit easier.
      would they be the same as the rb26?
      - Adam
        Not sure. Probably since rb26 injector fit in the rb20 rail and manifold.
          hey Got2BeBoosted if u get a part number plz post it up
          - Adam
            You should be able to email or call your local nissan dealership parts department and they should be able to look it up. or if somebody has that parts catalog program thing they can look it up.
            Rusty 240sx 1JZ project.
              16412F or 16618-78A00
              Found those on fast, should be good.
              Regards,
              Ken.
                So these are supposed to be for the rb20 i take it ?
                if so i am going to stop by my nissan dealer today and confirm weather or not this works if so i will let you guys know for sure.
                  same as RB26 seals.
                  also 4g63 seals. (old gens)
                  and FD
                  basically 11mm top mount bosche style injector seals.
                    thanks for the part number, i tried 240sx seals(read somewhere they worked) but they still leaked.
                    hopefully when my engines back together with these seals in place it will be dry as a bone
                    - Adam
                      also, those numbers..are they for an individual seal/o-ring or is it a "seal kit" because there's 3 seals needed per injector..
                      - Adam
                        Theres an insulator and o-ring that sit on the fuel rail side of the injector, and another insulator on the tail side of the injector.
                        16412F 16618-78A00 O-Ring
                        16603F 16635-78A00 Fuel rail side insulator
                        16603G 16636-V5000 Tail side insulator
                        I looked at gasket kits but there all in Japanese and I couldnt pasted the characters into a translator. Let us know how it goes.
                        Regards,
                        Ken.
                          wow sweet man, where you finding these numbers exactly? (if u mind sharing)
                          also you think the only thing that should be changed is the o-ring?..the others being named insulators i assume they don't actually seal anything? just for vibration?
                          - Adam
                            I looked it up on Nissan FAST
                            I havent swapped out my injectors yet, Im planning on dropping some in deatschwerk's or maybe sard's when I upgrade my turbo, intercooler, and computer. I assume its just the one o-ring from what I have read on forums, they always say to replace the o-rings, never heard anything about the insulators.
                            Regards,
                            Ken.
                              Hope this helps
