title should say stoooopid*
So i ****** up last night, I Drifted a corner, but i over slid because of the rain and when i corrected the car i hit the curb. The front drivers tire hit the curb at about a 45-50 degree angle and then the car bounced back into the road and i believe the rear drivers tire also hit but not as hard.
Everything appeared to be ok after the incident, but on the way home the front driver tire rubbed on smaller bumps/dips than usual and on sharp right turns.
I took the 2 front tires off today to inspect all the suspension components but to my surprise everything seemed to be completely ok. Both sides looked the same and nothing is bent or cracked.
So my issue is my drivers front tire is sitting slightly (just the smallest bit) closer to the rear of the wheel well. making it rub more than it used to.
At this point all I can think of is taking it for an alignment...what else would you guys suggest doing/ looking at?
