Just did a timing belt,idler,spring and tensioner replacement,i changed the water pump to but a used one.Changed all the fan,A/C and ALT belts too.everything was fine on first day except for the crank pulley that sounds rattle,it is hitting my lower timing belt cover.
The second day suddenly i have a large amount of radiator fluid spill coming from the hole of the water pump.decided to park the car and wait for new water pump and crank seal.
decide to use it again and the spill is gone,but it was replaced by a "SQUEAKY NOISE".When the engine warms up it will disappear.
Question:
Is it my water pump?Or might be the fan,a/c ad alt?How tight should the belts be?
Can i change the water pump with out removing the timing belt?
Please advise me.thanks
Question:
