Can it also be a throwout bearing? Eitherway, I doubt this is a job I can do myself now... guess it's finally time to fork over cash for this car!
Clutch Issue
Release (throw out) bearing is engaged/disengaged by the clutch fork which pivots on a ball stud just inside the bell housing. If the pivot ball stud is damaged the fork isn't sitting right or engaging/disengaging the release bearing properly. This prolly why you can still, sort of get into gear but with a lot of play in the pedal. In essence, your clutch fork is just flopping around doing nothing. Also why the fork seems loose and the slave pins not seated through it properly. The ball stud itself is like, $15 and I believe it's the same as a 300zx one... But yeah you gotta go inside your transmission now. You should be able to look inside the dust boot on the right side of the bell housing and see if the studs broken. Wouldn't hurt to switch out with a new slave at the same time...
Did a quick search, theres Nismo ones you can get as well for around $10-$15...Last edited by Ghost; 06-19-2011, 02:10 AM.You gotta pay to play.
Perfect! I'm bringing the car to NelsonMX tomorrow to have it all worked out. He'll take care of it for sure. I'm definately considering swapping out the CMC and the Slave at the same time, might as well...don't want to run into a problem like this again!
Oh and as for the ball stud.. it's for sure the same as the 300zx?1991 Black GTS-T
Air in lines makes it easier to push down not harder... Sure way to know if your release bearings screwed is you'll hear it scraping/ squealing in the trans, and it's loud and very noticeable. Weakest point on these clutch systems is the pivot ball stud.. Not uncommon that these break.You gotta pay to play.
Theres no noise at all from my transmission. I doubt it's just air in the lines because of the fact that there is so much play in the clutch fork... it has to be something inside the tranny if so correct?
My buddy is going to take the tranny apart either tomorrow or day after, so I'll be sure to give you guys an update.
I'm going ahead and getting a bunch of other stuff changed/ fixed at the same time.
Following all the knitty gritty annoying maintenance stuff, going to start installing all my goodies! Tough owning a skyline when its not running, but it should be well worth the wait.1991 Black GTS-T
It is and it will sir. I bought mine not running... 8 months it sat as I fixed and meticulously picked through and fixed/tuned her up... 8 months later I'm getting to the performance end... And it's a whole other world of pain then. But that's part of the fun
lol to be honest, i have never bled my system and i have the whole soft til the last 2 inches engagement thing i know it is not proper but i like the feel better than a fully bled system, quick engagement, no catches, no leaks, good clutch, possibly an air pocket is what im guessing but im used to driving with it and i never lose feeling and miss my rev match or over rev when letting the clutch out so i think im just not going to touch it. it works fine.... i dont want to bust anything by messing with itOriginally posted by DarkCaporaL View PostSo it's soft or hard?
If it's soft and only engages at the last 1/2 inch of the pedal it could be a leak, an air bubble, a failed master or slave. I would start by inspecting for leaks and attempting to bleed the system. Have you checked your reservoir? Sometimes this can get low and suck up a huge air bubble if you keep it low.
If it's hard and you can't press it down it can be a blocked line, loose cable or throw out bearing.FWD = Fukin Wont Drift
Bet it feels good it's not a $600+ problem
Weakest part on the whole clutch system... hope you get a new one soon and get back to driving soon!
Cheers!
For the record a lot of people also mistake this issue with a bent clutch fork. Mainly cause the fork will sit sideways and appear bent when you look at it where it enters the bell housing.Last edited by Ghost; 06-20-2011, 09:19 PM.You gotta pay to play.
