So I found the source of my car searching for the idle every once in a while. My Super AFC is not set right. And everything I set it to just makes it worse. Its the first generation model with the 5 knobs (one, 800.. two, 2400.. three, 4000.. four, 5000.. five, 7000..) i think that is what the knobs are labelled as. I am not familiar with this at all. My RX-7 had a 2nd generation model that was all digital and I understand how that one works but these knobs make no sense to me. Ive googled it a bit and basically all Ive deciphered is that the S-AFC is tapped into both the Throttle Position Sensor and Oxygen Sensor..
The only thing I can think of to maybe help someone help me out is that when I was swapping parts for my car to pass safety, I had to remove my screamer pipe and put a stock downpipe on from my friends RB20. Im lazy as hell so I didnt bother taking the oxygen sensor out of my screamer pipe and putting it in the stock one (instead I bought a Cherry Bomb O2 sensor plug.. its just a plug so it doesnt leak exhaust from the hole). Then during the time that I had the stock downpipe on (with no O2 sensor connected), I reset my ECU hoping that would solve my problem. It really didnt do anything.. I think it made it a TINY bit worse. Then when my car passed safety I put the screamer pipe back on and reconnected the O2 sensor.. I have not reset the ECU since the O2 sensor has been plugged in again.
Another thing, when my car is doing its funky idle searching, if I take it on the highway for about a minute and get back into the city, it will be idling normal (sometimes normal at 1,100 rpm and sometime like 1,500 rpm and a couple times sitting at 1,800 rpm for a bit haha)
I hope thats enough info. Maybe someone can help me figure this out.
