R32 wiring.
  • R32 wiring.
    I am a little lost on finding a few wires needed to get my swap running.
    I am wiring another nissan harness to the 3 plugs near the ECU. I am using an S13 swap guide and replacing the S13 stuff with the R32 stuff.
    The wires I cannot locate are:
    - Consult pins 6, 9, 13, 14
    - 12v coil relay switched (12v power that is turned on when the coil relay is triggered)
    - 12v on/start (power from 10a fuse when Ign is in On or Start positions)
    - 12v constant (there are two needed, one is 25a from the same circuit as ECCS and coil relays, the other is 25a from the engine bay fuse box)
    here is the link to the wiring guide ive modified
    91VHto91R32.xls
    Just one step on my way to Eleventy Billion horsepower.
