I feel your pain dude. Last comp test i did i got about the same numbers. Try putting a few drops of oil in each cylinder and run the test again. I got about 10 psi more across all cylinders which points to worn rings. Im still undecided as to if i will rebuild in the winter or or swap in a healthy rb20. In the meantime i just cranked up the boost.
