FPR Help
  • FPR Help
    Hey all, just finishing up my build list and started buying things and I realized I forgot to include an FPR. I managed to find a Nissan FPR adapter plate, just don't know what I'm looking for in an FPR. How many ports and what kinds does it need? Should I pick one up with a gauge on it too?
    There was a member on here selling a brand new FPR can't remember the brand but it was good. I run a Aeromotive FPR it's the big one, cost $140 shipped to my door. It is completely rebuildable and comes with a gauge. The best part is aeromotive is a huge company so parts are easy to find.
    Not sure if you understand how a FPR works but simply it's a small diaphragm thats controlled off the engines vacuum line. The fuel supply line on your fuel rail is being fed directly from the fuel pump (this is where guys "t" into the feed line to run 2 feed lines to their fuel rail) At the end of the rail you install a hose that will then connect to the FPR and from the FPR to the return line back to you fuel tank. So most have only 1 port in ( return line ) 1 port out ( to fuel tank)
    Oh it was a SARD that's for sale !
