rb20 base map for haltech platinum pro?
  • rb20 base map for haltech platinum pro?
    Anybody got a base map or any map I could modify for an rb20det running a haltech platinum pro ecu? I know their site says to swap pins 112 and 114 on the factory harness to run it on an rb20det or rb25de, but the only base maps I found were for rb25det and rb26dett. Any help would be awesome
    Anybody got any advice? Should I use the rb25 map but change the displacement and injector size and what not?
      I take it your planing on geting a tune? Just make sure it idles ok and trailer your car there. A lot safer and less hassle I think if anything were to go wrong.
      92 Gtst/Silver bullet
        Installed it today, uploaded the rb25 base map, then changed the engine displacement to 1998cc and injector size to 270cc, that's all. Oh, and of course I swapped pins 112 and 114 before doing this too. So I loaded the map and turned the car on and the idle was beyond erratic and lumpy. It would idle between ~800-1000 rpm and not stick to one at all. No fault codes were thrown off though. Also, my injector duty cycle was going into the -2000s-3000s and that was flashing red. What do I have to change to get this to run properly???? Or, does anybody got a base map that I could use???
        Car idles fine on stock ecu and runs fine on no boost btw
