Hey all, I'm planning on changing my timing belt in the spring as I don't know if it has been done yet and I don't want it breaking and my engine ending up ******. I'm just wondering if I should change just the timing belt or the tensioner pulleys and stuff too. I've seen the oem mitsuboshi timing belts and I have also seen kits including the following;
1 Mitsuboshi timing belt (made in Japan)
2 Genuine Nissan camshaft seals (made in Japan)
1 Genuine Nissan crankshaft seal (made in Japan)
1 Genuine Nissan tensioner spring (made in Japan)
1 NSK Tensioner bearing (made in Japan)
1 NSK Idler bearing (made in Japan)
Is it worth it to replace all of that or should I just grab the timing belt? I got about 130k on the engine btw
