A friend of mine bought this thing already swapped. It had a bunch of boost leaks, and I've fixed those. Everything is stock. It has low power. The boost gauge reads 12 psi, I can hear the bypass valve working when I let off the throttle. It revs smoothly, and idles smooth. It has red valve covers and the ceramic turbo.
I'm thinking it is lacking fuel. I'm guessing it should be getting 3 bar? It has the stock fuel pump.
If it's not fuel I'm guessing it might be out of time.
I don't think it should be hitting 12 psi either. It has the stock wastegate and the hose is connected to the pressure side of the turbo. I checked the wastegate and it's working.
