Hey everyone, im looking onto buying these GTR dump pipes and I was wondering if anyone knew what brand they were. Are the descent quality? Has anyone used these before? Thanks
His and ebay. Even if they are hks that design has been proven less efficient than the tomei style. Quality will be fine from hks, not good if ebay item.
The single bellmouth dump / outlet pipes are bigger with diameter which is what you need. The twin pipes run a small diameter main pipe (similar diameter to stock dumppipe), with smaller pipe for wastegate that's aimed at wrong angle into main pipe.
Here's a Japanese tuners opinion on those types of dump pipes and what he recommends from his experience -
Is he saying that even with boost set on just actuator pressure or 0.5 bar that it creeped to 1.3 regardless? Could that be why my boost goes to ~8psi which I believe is the actuator pressure for the turbo I have, and then at higher rpm it creeps to around 14+
