i understand all vg30de (z32) clutches will fit in the HNR32. is that the same for the other components in the bell housing? ie. pressure plate, flywheel, release bearing, and all that stuff?
another clutch thread
If i remember correctly
Bell housing does not work
If looking at aftermarket clutches pressure plate and disc are the same
flywheel i "think" is the same not positive
Best bet is just use google and compare part numbers, there are lots of cross over threads even on this forum should be mentioned
Clutch disk, pressure plate, pilot bearing, release bearing will all fit no problem.
I don't know 100% on the aftermarket flywheel fitment though, I would assume as the vg30de after market flywheel was good for the HCR32, it would also be good for the HNR32.Originally posted by Paradis^^ hows not being rich going? ...haters be hatin
