Having trouble diagnosing what is likely an ignition problem but who knows?
Slightly inconsistent idle, drops very slightly now and then and can get worse to the point of hunting when engine is really warm.
Will not hold a constant speed @ 50-60kms bucks on and off on light throttle pressure.
Seems there is a dead spot around 2000rpm. revs will drop if held, but will push past.
TPS sensor reads .48V on idle and increases steadily to just over 4V @ WOT.
MAF has just been removed and cleaned.
Nistune ECU
Any ideas?
Nistune ECU
Any ideas?
