Hey guys, I am looking into why I'm over boosting. while I'm driving I can hear air coming out of the BOV (which I see is routed back into the the intake, downsteam from the MAF) on my gauge it shows that I'm boosting at 14 psi and its all stock.
I pressured up the BOV on the bench and it opens at 7PSI.
I pressured up the wastegate and it starts to move at about 13-14 PSI, it opens and closes fully.
That makes sence that its boosting at 14PSI but I thought it was all stock.
On the right side rocker cover there is some 5/8" hose that also leads into the downstream side of the MAF. In this small hose there is a little steel thing with a hole in it. There is a bit of oil coming through there and going into the turbo compressor side. The PCV that is on the intake manifold worrking correctly.
It does not consume oil and there is virtually no crankcase pressure/ blowby.
Also, what would be the lowest safe oil pressure reading I should see. With new oil, when its hot sometimes it drops down to 2 cm squared at idle... This seems low to me and I hope the main bearings aren't going!
