injector size....?
  • injector size....?
    i wondering what size injectors i should get? i have a top mount turbo manifold. 57 trim turbo. FMIC etc. straight pipe. would stock gtr ones work or should i go bigger? greatly appriciated!!!
    All depends how much boost you are runnin and your power goals. Can you be a little more specific with the setup and intentions?
    R33 GTST RB25DET series 1
      1cc=about 1hp so 440cc capable of 440 hp and so on if you want 500 hp dont get 800cc injectors get 550cc
        ^^^^^^^^^ Correct keep in mind that ratio is hp at the flywheel, Take what you want to make at the wheels add 20% and you should be close
          +1
          I am running 555cc injectors on a highly modified RB20
          1989 Skyline GTS-t Type M (Bee-R powered)
          1991 BMW MK Motorsports 850i
          1992 Widebody Mercedes-Benz 400E
          1995 BMW 325i Convertible
          1998 Toyota Avalon XLS (winter beater)
          1993 BMW AC Schnitzer 320i (SOLD)
          1992 Mercedes-Benz SL500 (SOLD)
            another thing to consider too is duty cycle. Once you figure out how many cc it takes to run your motor don't be afraid to go a bit bigger yet so you keep them around 80% duty cycle. My 25 is putting out 400whp i'm running 550CC injectors just over the 80% duty cycle mark.
            Math break down 400whp + 20% to flywheel = 480cc + another 20% for duty cycle Puts me at 576cc. So My selection of 550 is close enough.
              agreed dont need to over work an injector thats to small to make the power
