Im a complete newbie when it comes to turbo cars so please forgive my ignorance. When i jump on the gas in my 93 gts-t and the boost builds it makes an almost squeeling/screaming sound. I can tell its spooling, the car pulls hard and as far as i know the boost is building completely. I know turbos do make sounds when they spool but this just sounds a little off to me. Can anyone confirm or deny this sound of a stock RB20 turbo?
RB20 Stock Turbo Sound
Squealing usually indicates something rubbing internally or a bad bearing. My rb25 turbo squeals like a bitch, no shaftplay and shaft spins freely by hand, and builds perfect boost. Kinda sucks cause I had to switch back to an rb20 turbo which doesn't have as much punch. Try and source out a replacement ASAP before the oil seals let go as mine did.
Sent from my iPhone using TapatalkLast edited by Voodoo_ChildR32; 03-23-2012, 05:47 PM.1989 R32 Skyline GTR SOLD!!!!
-Bruce Lee
Sounds like a boost leak. If your car runs fine when off boost it could be a loose coupler that only leaks when its building boost. Try doing a pressure test with an air compressor, if theres a leak youll hear it.I canz take this corner at 195k cause i gots AWDZ. Get real.
Usually a boost leak in intake piping after turbo. But if fix boost leak and sound doesn't go away it can be the compressor wheel touching compressor housing (how stock RB20 turbo failed on my car and made whistling sound around 0 on boost gauge and when it got worse there was a wackng sound). Another area is BOV flange gasket (gasket is not replaced when BOV is removed, refitted).Last edited by Skym; 03-23-2012, 08:56 PM.RESPONSE MONSTER
take a PVC end cap the same size as your piping. drill a hole and install a valve stem. Disconnect the piping and attach the end cap.
Pressurize and listen for air escaping. Don't pressurize too much though1989 Skyline GTS-t Type M (Bee-R powered)
1991 BMW MK Motorsports 850i
1992 Widebody Mercedes-Benz 400E
1995 BMW 325i Convertible
1998 Toyota Avalon XLS (winter beater)
1993 BMW AC Schnitzer 320i (SOLD)
1992 Mercedes-Benz SL500 (SOLD)
That doesnt sound like a boost leak it sounds like a rabbit being eaten alive!Originally posted by Slider15 View Posthopefully this video works, let me know what you guys think after hearing it.
http://vimeo.com/39083222I canz take this corner at 195k cause i gots AWDZ. Get real.
I agree do both tests
Boost Leak Tester DIY
http://www.youtube.com/watch?v=atretf9u-Mc
How much shaft play should a journal bearing turbo have?
http://www.youtube.com/watch?v=uH5YUw4kOQk
Another option is find a turbo shop and have them rebuild the turbo to be able to take more boost.Last edited by clone; 03-23-2012, 09:04 PM.1993 GTR
1992 GTS-T Type - M (Sold)
