Anyone know where this noise is coming from?
  • Anyone know where this noise is coming from?
    after the car starts, it makes that 'currrk' noise. is it the starter?
    all stock except for intake. the red wires - grounding kit, not connected, just preparing the layout, and it doesn't interfere with that noise.
    thanks
    Sounds like the starter could be overcranking.
    "Syntax with a steering wheel."
    Volkswagen R32 Daily
    Nissan R32 Skyline Summer Car
      Mine does that now and then also. Mostly on cold starts
      Igniter pack?
      R33 GTST RB25DET series 1
        do you have trouble starting on cold starts? i do. that video is when the car was warm, so it started fine, still made the noise tho. but i have trouble on cold starts. ill post a cold start video soon.
          Sounds like a loose auxiliary belt slipping on pulley. Put some belt grip on auxiliary belts and see if it goes away. Auxilary belts should be changed every 20,000km and adjusted every 10,000km.
          Cold start is usually ECU tune related (start up tables need to be retuned).
