this issue started about a week ago. i had a bad pcv valve (it was hissing) and in my retardation of trying to fix it i somehow destroyed my car's ability to idle. as it sits now, when it's cold it won't idle at all. it doesn't struggle, it doesn't chug. you start it, it dies within 2 seconds. when it's warm, it will idle for about 30 -45 seconds, then it will struggle and the rpm will slowly drop until it dies. if you unplug the tps it idles, but very rough. it constantly tries to die but catches itself. plug the tps back in and it dies instantly.
here's what i've tried;
while i had the pcv valve issue i tried blocking it off at both ends (valve cover and intake manifold) still wouldn't idle.
changed the pcv valve. still doesn't idle.
cleaned the iacv. still doesn't idle. (idle control works while the tps is unplugged, seems to make no difference where you set it. it always dies.)
if you unplug the maf it idles for about 10 seconds, gets very confused, and then dies. (as expected)
checked every vacuum hose i can find. no visible disconnects or audible leaks.
checked all the vacuum connections i can reach on the intake manifold and they all seem to suck air.
i've done most of the regular maintenance **** within the last month (new plugs gapped correctly, cleaned the maf, cleaned the coil packs, new fuel filter) the car runs mint perfect aside from the idle so i have no idea where to go from here. i am as confused as i've ever been and i want it to end!
