RB25det question
  • RB25det question
    When Dan and I were rewiring my 1992 r32 with an RR25det we didn't know what it was.
    just under the joined line is
    On the left side, between my charger piping but infront of the intake manafold
    Started rebuilding my skyline when i was 18
    1992 GTST RB25DET
    http://forums.gtrcanada.com/gts-project-cars/54849-saved-my-car-great-scrap-heap-sky-redo-my-first-car-thread.html
    Originally posted by Bravo
    PS My wife just told me I was shitting in your Cheerios!
    I'm sorry,
    Good luck!
    bump still dont exactly know what it is..
    1992 GTST RB25DET
    I'm sorry,
    Good luck!
      That is the VCT solenoid
        is it important?
        like makes the car run better?
        1992 GTST RB25DET
        I'm sorry,
        Good luck!
          yes. running the rb25det ecu and vct make the midrange way better.
            its only running an rb20 ecu... i think, i looked at my case and i cant get my screws out because they have been stripped
            1992 GTST RB25DET
            I'm sorry,
            Good luck!
              what pin on the ecu would i splice into?
              1992 GTST RB25DET
              I'm sorry,
              Good luck!
                It's explained in this link, how different VVT settings affect's powerband (scroll down until see "Making a good use of VVT") -
                This link tells you when VVT is engaged with stock R33 RB25DET cams -
                For running VVT you need a modified internally (so plugs into factory RB25DET loom) 300ZX / Z32 ECU with Nistune installed + Z32 MAF + Z32 MAF plug and a retune. Or use stock R33 RB25DET ECU, stock R33 RB25DET MAF, etc.
                Or could fit aftermarket Link G4 ECU or ViPEC ECU + IAT sensor, Mac boost control solenoid with retune.
                  I also have Apexi AVCR, would I just wire it to that?
                  Aftermarket performance products. Founded in Japan in 1992, A’PEXi has grown from just a small tuning parts manufacturer to a multi-industry international powerhouse. 2018 marked the 20th year for A’PEXi USA and the 26th year for the A’PEXi Group of Companies.
                  1992 GTST RB25DET
                  I'm sorry,
                  Good luck!
                    No.
                    You could use a MSD rpm activated window switch to turn VVT on and off -
