94 gts-25t
EDIT:
well.. parked the car the other day so i decided i would take my valve covers off and check everything out see whats up and i find this..
the 100xxx km servicing was just done 2,000 km's ago. im assuming this has been my lean idle issue? rubbing against the back plate messing with my timing at idle but under boost there was enough power that it rubbing didnt make a difference?
Another EDIT:
pulled it all apart now, tensioner looked like it was cocked sideways a bit but it was hard to say. anyways took both the idler and tensioner off, made sure i put them on properly and nicely, swapped on my old belt that i think has 8k on it (hopefully) then spun it around twice by hand with the tensioner backed off, then tightened it and spun it twice again and the belt seems to stay in place but i guess we will just see. going to re-assemble and run without the timing cover to make sure it isnt wandering anymore and hopefully it idles normal again!
EDIT:
Another EDIT:
