[Like the title says
For the record, my feeling of my car being slower then normal is I've seen another skyline w/ an oem rb20 pull alot faster then I do.
Car tends to sound like a misfire at high rpm (about 5k+) Typically only at about 75%+ throttle if I slightly hold it down, and hit right to 5k+ it usually doesn't do it. Could this be a sign of bad compression?
Lately (Since the pod filter + BOV) car seems to feel gutless and alot slower (This also goes hand in hand w/ the above question, it may NOT be from either) Could these on oem engine + tune be fine? I've heard of everyone saying that every bolt on is fine.... but not sure why it's doing this.
What would you guys recommend to CHECK and/or change to fix these problems?
