im in the process of my rb25 neo swap and everything is done, its just a matter of wiring and getting it to start up. the r34 engine harness is all set up to plug into the r32 chassis wiring. i cant figure out my my fuel pump fuse keeps blowing. ive gone through three 15amp and one 20amp fuses.
im completely stumped as to why it keeps blowing. it worked fine with the rb20 installed. the only part of the circuit ive tampered with is the ecu fuel pump relay wire and that's now hooked up to were the rb20 fuel pump relay wire was connected to the chassis wiring.
any ideas? anyone that's done a rb25 swap run into this problem??
