If the pressure you are seeing now is consistently less than 70psi and your current stock pump is not worn out, then a N1 pump won't remedy anything. An aftermarket pump with larger volume is the only way to go with larger than stock bearing clearance setup.
Originally posted by BenOswald
View Post
