Hey so my tps circuit is all messed up and im in need of a new one...(my fault for crappy adjustment), just curious if an r33 gt-r tps is interchangeable with a r32 gtst tps? thanks!
R33 tps on R32 gts?
R33 TPS has a voltage trigger (software) for idle and I think WOT contacts and they removed idle, contact pins from TPS. R32 TPS has 2x contact pins inside TPS and no adjustable voltage triggers with software on ECU side.
With Nistune for R32 ECU, you have the option to run R33 TPS, as they have incorporated voltage trigger in the software / firmware on Nistune board. It's for when running R32 ECU on RB25DET engine.Last edited by Skym; 08-25-2012, 11:54 PM.RESPONSE MONSTER
