hi, i just bought my skyline about a week ago and it had some bogging issues. its a 1992 GTS-T with a RB20DET. its running about 10 psi boost. compression is good. its 134-137 across all. Idle seems to change between 900-2000. we told the previous owner that he would need to fix the bogging, which he said was just the TPS. he thought fixed it, until we drove it home. about half way through, (30ish minutes) it started to bog at 4000rpm. he told us that the TPS would need to get replaced/adjusted. we replaced it with one and it seemed to be fine. we have it set at 0.48 or so, which is what iv read it is supposed to be at. we cleaned the MAF we also checked the IC hoses for leaks. we found one hose clamp that was stripped, so we replaced it. it seemed to fix it momentarily, but it went back to bogging. today, we took off the coil pack cover, took off the coil packs, they all seemed clean and in good condition. they were recently replaced. they are yellow jackets if that helps :P we also took out all the plugs, checked them, re placed all 6 with brand new delco cross referenced (41-602) plugs that we gaped at .8mm. we put it all back together, started it up and it ran SMOOTH. best iv heard it yet. drove it around for about 30 minutes, (usually starts to bog after 5 minutes or so) ran GREAT. very fast, responsive, NO BOGGING. after 20-25 it started to bog again at 4000rpm and wont go over. (sounds like its hitting a rev limiter) i was very disappointed. it seems to run great after it has cooled down for a while. in the mornings it runs great, and after work when it hasn't been run all day its good, but only on cooler days. so when its cold it runs smooth, when its warm it bogs. the warmer it is the lower it bogs. if its really warm out and its been running for a bit it will go down to 3000rpm even. or even if it hasn't been running for a few hours and its just been sitting in the sun in 28*c it will bog with out being driven to warm up at all. iv seen a few forums on here about things like this but nothing that seems to match it exactly. not that everything will be the same but not close enough to make me think that its the same problem as them.
If anyone has got any help, or has experienced this issue, please help. i love this car and want it to run smooth again! <3
Thanks in advance!
Thanks in advance!
