does anyone have the info on how to hard wire in a injector drop resistor to a 1990 gts-t? i have a rb26dett installed and a rb26dett engine harness.
Wiring question???
If you have the proper drop resistor already, wire switched ignition power to the resistor then out to each of your injectors, pretty straight forward. Injectors always have power when ignition is on and te ecu ground them. The stock drop resistor is located on the front of the left shock tower. hope this answers your question.
Polarity (direction of current flow) doesn't matter through the injectors but oem has all power on pin 1 on the connectors (left). Better to do it this way in case you ever have issues down the road and need to diagnose, its easier if you can follow a factory wiring diagram.
