Turbo for rb20?
  • Turbo for rb20?
    Hey There,
    I currently have a RB20DET with a • 55mm inducer compressor wheel
    • "E" compressor cover 3.0" inlet/2.0" outlet
    • 57mm exducer T31, 76 trim turbine wheel
    - T3.63 A/R
    • 360° journal bearing system
    I'm currently making 355whp at 20psi.
    I want to change the turbo to a smaller one because of the lag, what size and mm should i switch to? I still want to make above 300whp
    Turbo size calculator -
      Switch to a garrett BB unit of the same size. Gt2871r
      92 Gtst/Silver bullet
        Holset hx35 is a good choice. Lag isn't entirely terrible and it will boost more than your engine is probably willing to take. You can easily maintain the same power level.
          ^wrong. Listen to supraclean
            Have you tried a good tune? And by good I mean tuned for the larger turbo. You should be at 32 to 36 deg. of ign. advance just before you hit about 7 #s of blow. Makes a huge difference.
              i think i'm going to switch the rear housing to a .48 and hopefully that will take the lag away. It should
                Have you even tried this set up before? It will be extremely laggy.
                  I have a gt2871r and love it! The response is amazing! Supraclean is right.
                  "Syntax with a steering wheel."
                  Volkswagen R32 Daily
                  Nissan R32 Skyline Summer Car
                    What turbo works on SR20DET works on RB20DET (both 2 litre engines). But I think exhaust housing A/R is where the difference is to get the response on both engines.
                    Sometimes it's the intercooler size, camtiming, exhaust size + shape to just name a few. Without knowing the setup around the turbo, hard to say what's causing the lag.
