Hey guys I'm looking for the rb20det harness part number, if you can help me out that would be great. Cheers
Rb20det harness
Rb20det harness
Started rebuilding my skyline when i was 18
1992 GTST RB25DET
http://forums.gtrcanada.com/gts-project-cars/54849-saved-my-car-great-scrap-heap-sky-redo-my-first-car-thread.html
Originally posted by BravoPS My wife just told me I was shitting in your Cheerios!
I'm sorry,
Good luck!Tags: None
Which harness??? Why I ask is there's more than one in the engine bay with different part numbers. There's passenger side, drivers side, front of engine bay, then engine sub harnesses like injector harness, ignition harness, battery cables, etc.RESPONSE MONSTER
im looking for the engine harness, so not includeing headlight, taillight, or fuseboxStarted rebuilding my skyline when i was 18
1992 GTST RB25DET
I'm sorry,
Good luck!
so which part of the engine harness? injectors, coils, maf, throttle body, temp sensors ect.or do you want everything? i suggest if you havent already go through your grounds most wiring issues are shitty ground well worth saveing the money on a harness if you dont fix the original problemTO GRIP OR NOT TO GRIP.... THAT IS THE QUESTION
i want to replace the whole harness i have a r32 with an rb25det swap that runs like crap, and im guessing that the harness and ecu are to blame and the harness is mangled, so im looking for the part number for the rb20det harness.Started rebuilding my skyline when i was 18
1992 GTST RB25DET
I'm sorry,
Good luck!
Rb20det ecu, and I'm going to use bits from the rb25det harnessStarted rebuilding my skyline when i was 18
1992 GTST RB25DET
I'm sorry,
Good luck!
