RB25 injectors swap to rb20?
  • RB25 injectors swap to rb20?
    Do the rb25 injectors swap into the rb20 intake mani/connectors ?
    *assuming you swapped fuel rail as well.
    why not get gtr injectors and resistor pack? might be easier?
    Currently rollin' in a 1997 Nissan 240sx こうき
      370cc CA18DET (240SX / Silvia) injectors swap over and work with stock fuel pump, but need a ECU retune and I think a resistor pack for injectors.
      Easier, better to buy Deatschwerks injectors (new, drop in, matched to within 1-2% which is important with stock ECU) -
      Upgrade with DeatschWerks' high-performance fuel injectors, pumps, regulators, lines and fittings. Engineered for 400–2200 HP, built for racers and tuners worldwide.
      With any of the above options you'll need to retune ECU to suit.
        are you affiliated with deatschwerks at all? cuz everything you do is recommend them... just wondering... curious is all. not trying to bash you...
          Deatschwerks has a good product for a fair price my buddy runs them in his 20 and they work awesome i plan on getting a set soon
          TO GRIP OR NOT TO GRIP.... THAT IS THE QUESTION
            plus 1 for Deatschwerks. Im running 440cc and its great.
                ∩___∩
               | ノ      ヽ
              /  ●   ●  | Hello there!!!
              |    ( _●_)  ミ
             彡、   |∪|  、`\
            / __  ヽノ /´>  )
            (___)f^f^f^f^f^f^f^┐
             |    | SKYLINE    │
             |  / |    For     |
             | /  |      Life   |
             ∪   |__________|
            1990 HCR32 (Black)
              No, just I noticed they use Bosch injectors that are used by alot of people at a good price.
                rb25 injectors are high impedance as well. My main concern is that they fit the intake mani and electrical connectors. Can anyone verify that?
                If I buy these, I'll multi meter the terminals and let everyone know resistance compares to stock rb20's. My gut feeling is that this is possible.
                  NOT the same connector solder the full injector harness from a rb25 in and solder in the sub harness as well ppl do this for r32 rb25 swaps to avoid swaping and spliceing harnesses, tho they use the rb25 ecu, as for their impedence i can not confirm that
                    Alight **** that....... I'm going either 440 cc aftermarket or GTR injectors.... way rather put in 6 resistors than be customizing a harness for an extra 100 cc.
