more steering angle needed !
First question for OP is, how far do you want to go?
second being, what can and cant you compromise in pursuit of more angle?
lastly, of course, how much can you spend?
My new setup could be 50+ degrees lock, but I have to limit it to ~47ish because I wont compromise tire/wheel size.
assuming a mostly-track money-no-issue scenario:
Have your steering-rack mounts on the subframe moved forward as far as possible.
Buy both the offset solid rack bushings and the S14 inner tie-rods found HERE
Buy the bent type S14 FLCA/TC -rod combo found HERE
Buy adjustable FUCA
Have a PROVEN and SKILLED fabricator mod your knuckles. theyre cast not forged like s-chassis, much harder to mod safely. I'd suggest decreasing ackerman to about 15% difference leading/trailing and shortening the steering arm quite a bit.
with a wheel no wider than 9" and no higher offset than about 20, the above will without doubt deliver 58+ degrees angle
