To explain more in detail
This is not turbo lag, I will be boosting @ full 9-10 psi (depending on gear) when this happens.
Basically, if I do a 2nd gear pull doing about 3k, it'll pick up fast to 4k, between 4-5.5kish it seems to be laggy....less power. Once it hits above that, car pulls like a mofo.
THIS IS NOT HESITATION, car is firing, it is not misfiring, it sounds fine.
Not sure if it is a problem or if this is normal? It's been so long since I've had my car in great running condition.
Probable causes I am going to address is a vacuum leak. Currently at -20 vacuum, and I am quite sure it is supposed to be -30?
Any input is appreciated
Thanks guys
- Stephen
Thanks guys
- Stephen
