So, as title says, having some major issues. The car now barely starts, pops a lot during idle, and gradually will get worse as I drive it. In the afternoon it wasn't doing too bad, but later on it started flooding out during a cruise if I held the throttle in the same spot for too long. When I went home it was to the point it wouldnt even idle. As soon as i would try letting the clutch and and give it slight gas to make it into my driveway it would just die. We've properly cleaned the injectors with a pressurized can, no luck. We've swapped mafs for a known working one, no luck. van is between -15 to -20 in.Hg and makes a healthy 10lbs of boost which it loves with no problems but maybe the neutral switch thinking its not in gear so it cuts power. ive figured that out so thats not a problem. But we've tried everything. We've sprayed every hose with brake clean and we get no difference. Has new yellowjacket coils and will be putting in brand new iridiums which i doubt will make a difference to my issue. We've sprayed all the intercooler piping. And on top of this without unplugging various tps and iacv plugs, it idles at 1700 and wont go down even after warming up. We're stumped. Help plz
