Steering solid bushing compatibility need help
S13 is almost the same as R32. Overall diameter is the same. However you will have to take the round sleeves from the old bush, and press them into the solid bush. The holes for the sleeves on te solid bush are a bit too small, and you may crack it trying to press them in. You will have to take the sleeves and bush to a machine shop for them to measure and machine the bush.
It's not a big deal, but does take machining.RightDrive Inc. Parts Manager
