my r32 4 door skyline is running a 25de neo with a N/A 300zx ecu the code im getting flashed is 4 long 2 short this (according to internet) is "fuel temp sensor" would this cause it to run mint for 10 - 15 minites then die like its starving for gas then go then die ect like someone is turning key off an on while driving? if so what do i need to purchase to get it running mint cheers
Fuel temp sensor??
my rb25det swap(before it went kaput). also had this code thrown on my nistune. when i ran the stock ecu it didin't throw the code. but just like you when i use a z32 ecu the same thing happens(the code). although my engine never stalled or died. iam thinking it's a compatability issue with the z32 ecu maybe.
