Hey so I'm having some issues with my r32 has s2 rb25 it runs good when cold idles fine a little high but doesn't sound like it's missing and once the car warms up it will go really lean then stall out. I had a safc 2 in before and did the same kinda thing went to apexi fc d Jetro have the map and temp sensor hooked up. and problem is still here wondering if anyone knows what could be causing this.
Mods are hks 2540 turbo
Walbro fuel pump
555 injectors
The power fc d Jetro
Fmic
Has forged internals
Stock cams
Spitfire coil packs
Just put new plugs in
Could tps or AAC valve cause this
Walbro fuel pump
555 injectors
Fmic
Stock cams
Spitfire coil packs
