So I'm on a bit of a time crunch since I was supposed to drive to Calgary tomorrow morning, but that's clearly not happening any more.
What happen : I drove my car to my mums house today no problem, but when I went to leave, my car fired up instantly but then died.
My tests: Turned ignition to "on" and listened for the pump to prime - nothing.
Double checked the fuel pump fuze - it's good.
Located the green relay in the trunk and used my highbeam relay to test that the relay isn't toast - still didnt start.
Undid the fuel line at the fuel rail and had the car cranked over - no pressure
I undid the fuel tank and removed the entire sending unit. I connected the pump to the positive and negative terminals of the battery to for a split second - powered on
Ok so my fuel pump is clearly not getting any power. Awesome.
Should I rip out my interior and start tracing this gremlin?
OR
Since my battery is located in the trunk, I could run a new power wire off of the battery with an 15amp fuze to the power wire at the relay?
What do you guys suggest I do now?
I've never experienced a wiring gremlin quite like this, and since I'm supposed to be in Calgary on Saturday/Sunday.
OR
