Rb25det in r32
precision 5252e 59mm journal bearing turbo
stock turbo manifold
external wastegate on 9 psi spring
circuit sports adustable fpr set at 48 psi
3" turbo back straight pipe exhaust
screamer pipe
FMIC
Freddy front feed intake
I need this tuned but I'm not planning on doing injectors for a little while. Just need to get the car running proper AFR #'s to keep as a daily driver.
Right now it's pulling timing under boost and running a 9.6 afr at wide open throttle.
11 afr while cruising. Any recommendations? I don't want to cheap out with a safc but I don't think I need to go all out haltech quite yet (car needs to get me through school first
) I wish I could nistune
but the 300zx ecu swap over doesn't sound like such a awesome idea after talking to the tuners.
screamer pipe
FMIC
