Hi guys,
I've been searching this forum for a trouble like mine.
I've recently installed a new SPEC stage 3 clutch kit. The kit included ; clutch / bearing / pressure plate and alignement tool.
I put the clutch on the right side ( trans side ).
The problem is, when I reassembled the tranny, started the car, there was no pressure on the clutch pedal, ans the clutch won't release and won't come back when at the floor. The only way to get the car moving is to put it in 1st gear and start it after.
I bleed the system more than once, no air. It seems like the slave cylinder doesn't push far enough. But there no pressure on the clutch pedal. My fork still straight and the pivot is like new.
I changed the slave cylinder for a new one.. Same issue. The only way i founded to disengage the clutch was to attach a bender on the fork and torque it until it disengage. That worked.
Is it fluid related, or trouble Inside the bellhousing ?
I know i might not be the only one, but I need to find the way to fix it fast.
Thanks
Thanks
