hey, I just recently installed an rb25 s2 in an r32 using the r32 tranny, aftermarket plenum and front mount intercooler. Further I am using the rb25 harness and ECU. I just have a few issues, hopefully someone here can shed some light.
1) temp gauge doesn't seem to get a reading, I have heard of using the temp sensor from the r32(the skinny one near the top of the rad hose)..anybody else have this problem?
2)my wipers do not work, I read that I can use the rb25 plug and the only issue was that they do not turn off unless you splice the orange wire in the plug into the r32 body harness plug. However my wipers do not turn on at all. Any ideas?
3)finally I have rough idle and it bounces between 1000-2000rpm constantly, i thought it was a vacuum leak seeing I dont seem to get more then 10 psi on my vacuum gauge and I believe it should be more around 15-17 (correct me if i'm wrong). If not can it be a problem with the TPS or something like that?
thanks
thanks
