So I built the top end of my rb25 series 2 over winter, did a bunch of mods, (front face intake,injectors,cams,oil cooler, Q45 throttle body, etc) but also upgraded the turbo to godspeed kkr560 (i know cheap but all i could afford at the time plan on upgrading in the near future)
So i installed it using the rb25 turbo oil restrictor that was off the motor, because the ones they gave me looked the same diameter but wouldnt work with the angle it was at,
Ran the 1st turbo for a month threw dyno, street driving a few days and one weekend of drifting, (ran at 14psi)
Took the turbo off to check it had severe shaft play, figure out my boost controller was spiking to 19psi didnt pick this up till to late probably so got a new turbo sent under warranty,
installed that (only thing changed was different oil grade)
Ran the new turbo this past weekend, ran it at 11psi , in 3 laps i filled up my oil catch can and there was oil everywhere ( way to much oil pressure or blow by) checked the turbo and same thing rank shaft play and blows lots of smoke out the back now,
So i know its a cheap turbo but theres gotta be a reason for the oil pressure or blow by seeing im only running 11psi thats nothing on those turbos
ill take a pic of my oil restrictor and post it up
maybe turbo gettin to much oil or not enough but somethings not right
