Hey guys.
I will install a front facing plenum ( only the top part that bolt to stock runner)
Its not for performance gain its only to clean the engine bay a little bit .
I only have 2 question . What to do with the pcv? Block it and run a hose from the exhaust side breather to a catch can with a small filter? Or drill and tap the plenum to fit it? Or...?
Also i will keep stock tb and water line that goes to it but in front of the stock plennum there is the bleeder .
Can i get rid of the bleeder and just connect the 3 hose together and then jack up the front to bleed it?
Or i was thinking of making a small aluminum block with 3 npt fitting and a bolt to bleed it on top.
The rest im ok ...vacuum, aac and air regulator will need a hose before the tb and i will also need to relocate the blow off but im ok with that.
Thanks!
Frank
Envoyé depuis mon SGH-I747M avec Tapatalk
Thanks!
Frank
