So I bought and TRIED to install new tires on my 1991 R32 Gts-T and got a bit dissapointed. It dosnt fit... XD DOsnt really matter since I'm pretty sure i'll be able to make it work. My question is: Whats me biggest 17in. tire I can fit in front? I am running a stock suspension for now and my tire (235/45/17) sits about 1cm away from my suspension... I was thinking about spacers (wich I have) but the studs that are on the car are too long and don't allow the mag to sit perfectly on the spacer
Also the nut with holds the spacer onto the hub hits the back of the new mag also not allowing it to sit properly :/. so Is there any way to make it fit? are there any spacers tha utilize ONE SET of studs but longer? I don't mind changing them since I already did in the back. Thanks for the help!
