Hey guys i just finish installing my ffp on my rb20
The first day everything was fine and my a/f was 10-11.5 at wot all to way to 7k rpm
Yesterday i adjusted my tps as close as i can to 0.5v closed like the fsm said. I did a test ride and everything went good!
But now my a/f is always changing in cruise . It jump from 10 to 15 to 13 to 14 to 12 always. In boost also its jumping alot so i'm not boosting at all to be safe.
Fuel pump is new
Fuel filter is good
Injector also
Could it be the fpr? I hooked the vacuum source for the fpr directly to a vacuum on the manifold. But on stock im its connected where there is the bleeder so is there a kind of restrictor or so?
Or what else can make the afr jump like that? Maybe a exhaust leak before the sensor?
Other option could be the o2 sensor maybe?
Envoyé depuis mon SGH-I747M avec Tapatalk
Fuel pump is new
Fuel filter is good
Injector also
