Hi everyone. Ive got a skyline hcr32 , i have the stock rb20det engine.
When i first start the car it has a hard time keeping idle and sometime drop really low, as low as 100 rpm, unless i give it gas to help it. After 20-30 seconds the idle stabilize but if i give it throttle it will missfire and bug down (wont boost at all), if i insist ill hear a popping sound that i suspect is coming from the intake.If i go in gear, It wont accelerate properly until i hit 2700ish rpm at which point it will all of a sudden rev and boost normaly.
This problem occur only when the car is cold, and settle as soon as the engine get to the running temp.
Please help !
Changed Maf and Ecu
New IAC ,front 02 sensor and Spark plug.
Coil have been tested
Please help !
Changed Maf and Ecu
