Ok i have a rb20 with lots done to it cooling and fuel wise are all good to go, still stock turbo but i have a custom stock Exhaust Manifold with external built into it and I'm going to be most likely buying a He351cw holset right away and its quite a jump from stock turbo but i wanna go big !! Has anyone ran one of these on stock internal motor??
Would this be a little to extreme for stock in terms of spool up? or would it be just right i wanna build the motor eventually too but for now i just want to get a whole new setup on it. i already know this turbo will bolt right up pretty much exactly the same as the stock one besides different down pipe and only oil cooled.
I'm not sure about the oil feed situation though with one of these turbos cant seem to find a strait answer on if it should be restricted and if i do jump to such a big turbo whats an safe low boost for something like that on a stock motor?
i already run 14.7psi on my stock one which i have been doing for the last 2 years with no problem but there is suck difference in size from the two.
Any info be great guys!!
