Hicas delete ecu and light
  • Hicas delete ecu and light
    I have installed Driftworks total hicas delete kit. Removed all plumbing and solenoids and removed the vanes from the power steering pump that powered hicas. I have a 1993 R32 GTS-T. The Hicas ecu is to the left when looking into the trunk,(boot). I cannot find any reference to the wiring so that I can cut the right wire to cancel the warning light on the dash. The pictures that I have found refer to the hicas ecu being on the right hand side. The plugs on my application do not look anything like the ones I have seen on the material I have found so far. Here are a couple of pics, can anyone tell me which wire to cut to eliminate the dash light.
    [IMG][/IMG]
    If memory serves me correct. I believe its the solid green with white stripe wire.
      Yes, I looked for that one, the closest I can find is green with a yellow stripe.
        Buy a Tomei HICAS lock kit -
        Purchase aftermarket performance parts direct from Japan including Apexi, HKS, Greddy, Nismo, Blitz, Spoon, TRD and other JDM brands at wholesale prices
        The wiring part of the kit turns off the warning light on dash.
          Thanks Skym but everything is done except the warning light and alignment, I will take my chance on the green with yellow tracer. I will let you know if it takes care of the warning light unless I can get more solid info on which wire to cut.
            why not just remove the light from the dash?
              It apparently indicates other faults.
              I just deleted hicas all together. Removed all the lines, capped the PS pump and removed the fins, Swapped in an S13 subframe with all new poly bushings and a new S13 steering rack.
              Jordie Lewis
              1993 Skyline Type M
