so I've got some r33 gts-t callipers and z32 drilled slotted rotors, trying to put them on a r32 gist. will this work? the diameter is smaller on the z32 is 16mm difference but I'm kinda in a jam here and way over my budget with some stuff. ideas?
brake help!
R33 brake caliper should bolt on the rear, front it might not without the hub to go with the caliper.
If it is a R32 GTS-T Type-M, R32 GTR brake caliper, R32 GTR rotor bolts on the front. The stone shield for front brake rotors is I think from a R32 GTR.RESPONSE MONSTER
