Hi all,
I have a s2 rb25 I am in the process of swapping into my e36. After getting the wiring done I turned the engine over with the igniters disconnected and I am getting zero oil pressure. It has been converted to rear sump to clear my subframe so after checking the pick up is clear and sitting at the right level and the oil level is correct I still have no pressure. I pulled the pump off and there is nothing wrong with it, and the port from the pickup to pump and pump to filter are both clear. Took off the filter and turned it over and not a drop of oil. I have had lots of people look at it and no one has had anyideas what the problem is. If anyone has experienced this or has any suggestions at all it would be greatly appreciated!
Thanks!!
Thanks!!
